 Forum de l'association French-Drift-Community • Consulter le sujet - Throw-in Handicap Betting: Concept and the Most Effective Be
Message par wintips123 » 20 Mai 2025, 05:34
Throw-in Handicap Betting: Concept and the Most Effective Betting Tips!
A throw-in is a situation that almost certainly happens in every football match. However, the way it unfolds can be diverse and unpredictable. That’s why bookmakers offer throw-in handicap bets. Although it's considered a side bet, this type of wager is still worth your attention. Are you planning to analyze throw-in odds? Don’t skip this article from Wintips if you want to improve your ability to read and predict accurate betting odds.
What is Throw-in Handicap Betting? Let a Reputable Bookmaker Explain
There are many articles explaining what throw-in handicap betting is, but a large number of them are lengthy and confusing. Let’s hear the simplest explanation from fb88 – one of the top betting site reviews today.
Throw-in handicap betting predicts throw-in scenarios.
Specifically, throw-in betting refers to wagers predicting throw-in events. A throw-in happens when the ball crosses the touchline. A player from one of the two teams is then allowed to throw the ball back into play under specific circumstances. From this, bets can be made on which team will have the first throw-in, the total number of throw-ins, or which team will have more throw-ins, etc.
Even though it’s a side bet, throw-in handicap betting is still popular because the number of throw-ins can be unpredictable and exciting. This unpredictability adds both tension and value to the bet!
Common Types of Throw-in Bets
Throw-in handicap betting doesn’t come in just one form — there are multiple types to choose from. Let’s go over the most popular throw-in bets today with fb88.
1. First Team to Throw In
The most basic type is betting on which team will take the first throw-in. There are two options: betting on the home team or the away team. When analyzing odds, you simply choose between the two options provided by the bookmaker.
Statistically, the odds are close to 50-50 since both teams usually contest the ball evenly. However, if the skill gap is large, you might prioritize the stronger team.
2. Over/Under on Total Throw-ins
You can also bet on the total number of throw-ins, similar to Over/Under bets for goals, cards, or corners.
If the total number of throw-ins is higher than the number set by the bookmaker, Over (Tài) wins; if it’s lower, Under (Xỉu) wins. If the total number exactly matches the bookmaker’s number, your stake is refunded.
See more: top 5 best basketball prediction site free
3. Throw-in Handicap Bet
In this type of bet, you wager on which team will have more throw-ins, factoring in a handicap. Only valid throw-ins are counted. You may win the full amount, half the amount, draw, or lose based on how the handicap applies to the actual throw-in numbers.
How Are Throw-ins Counted in Betting?
Not all throw-ins during the match are counted in the betting results. It’s crucial to understand how valid throw-ins are calculated.
Extra time and stoppage time throw-ins are usually not counted.
However, if a team performs an invalid throw-in and has to redo it, both the incorrect and corrected throw-ins may be counted.
Clearly, predicting throw-in scenarios isn't as simple as many assume. You need football knowledge, experience, and above all, a reliable bookmaker like fb88 to place safe and accurate bets.
Where to Bet on Throw-in Handicap?
Don’t assume you can bet on throw-ins just anywhere because it’s a side market. You should choose a trusted bookmaker like fb88. Here’s why:
fb88 covers a wide range of leagues and matches, ensuring you'll find the game you're interested in.
The brand is reputable, with little to no major controversies.
It offers clear payout policies, making betting and collecting winnings easy, fast, and hassle-free.
fb88 provides a rich variety of throw-in bets that aren’t available everywhere.
Must-Know Tips for Throw-in Betting
If you're interested in throw-in betting, here are a few important tips you shouldn't miss:
Choose the right bet type: You can bet for the first half, second half, or the entire match.
First team to throw in is a full match bet that gets settled quickly once the first throw-in is taken — nearly every match has at least one throw-in.
Easy-to-Apply Throw-in Betting Experience
Knowing how to place bets isn’t enough. These extra tips will help make your throw-in bets more effective:
Study each team’s playing style before betting. Analyze how they attack — if their play leads to more out-of-bounds situations on the wings, the number of throw-ins is likely to be high.
Teams with better ball control usually have fewer throw-ins, while those that attack down the flanks tend to create more throw-ins.
During the match, observe objectively and avoid emotional betting. Keep track of who’s dominating possession and how the match tempo evolves.
If the match is fast-paced with both teams attacking constantly, expect a high number of throw-ins due to frequent ball challenges and clearances.
Don’t assume the stronger team will always have more throw-ins. That’s a subjective judgment. You should base your bet on how the match is actually unfolding.
fb88 has just walked you through the world of throw-in handicap betting. We hope the knowledge and insights we've shared will be useful for you. Don’t forget to choose a quality bookmaker before placing your bets. Fb88 is always here if you need help, ready to offer exciting updates on football and betting.
Message(s) : 94
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 5 invité(s)
