 Forum de l'association French-Drift-Community • Consulter le sujet - Guide to Over/Under Total Goals Betting
Message par wintips123 » 08 Mai 2025, 05:11
The Over/Under Total Goals bet is an extended version of the standard Over/Under goals market. Similar to the regular Over/Under goals bet, this version offers a wider variety of choices, making it ideal for those who enjoy taking risks.
In the Over/Under Total Goals market, players can choose from 8 to 16 different Over/Under goal lines provided by the online bookmaker. These lines usually range from 0.5, 1, 1.5... Up to 7.5, 8, and beyond.
As a special type of bet, Over/Under Total Goals opens up opportunities to wager on almost unimaginable goal lines, which also come with equally extreme potential returns or losses. For example, you wouldn't normally expect a Chelsea vs. Manchester United match to have an Over/Under line set at 7 goals, right? And of course, each of these lines comes with payout odds that vary widely, from very high to very low.
However, what makes Over/Under Total Goals betting interesting is that it offers players a chance to place small bets for high returns, or to play it safe with modest but more secure profits.
How Winnings Are Calculated for Over/Under Total Goals Bets:
Winnings are calculated using European odds:
Winnings=Bet Amount x Over/Under Odds
Example:
In a Basel vs. Man City match, you place a $100 bet.
If the final score is Basel 0–2 Man City:
A bet on Over 1.5 wins: $100 x 0.16=$16
A bet on Over 0.5 wins: $100 x 0.0005=$0.50
You also win bets on Under 7.5, 6.5, 5.5, 4.5, 3.5, and 2.5
You lose the remaining Over bets.
If the final score is Basel 2–5 Man City:
You win Over bets on 0.5, 1.5, 2.5, 3.5, 4.5, 5.5, and 6.5.
For example, a bet on Over 5.5 wins $100 (assuming the odds are even).
All other bets lose.
See detail: what does 1st half 3 way meaning mean?
Tips for Betting on Over/Under Total Goals:
This market is ideal for those who prefer steady, lower-risk betting—small but consistent wins are the goal.
Choose matches where the standard Over/Under (handicap) line is around 2 or 2.5, and then place bets on Over/Under Total Goals starting from 4 goals and up. Your chances of winning will be much higher.
Compare odds across multiple reputable bookmakers to find the best payout rates.
Remember: bets where you stake more for a smaller return are usually safer and easier to win than those with low stakes and high returns.
Hopefully, this guide from win tips bet helps you better understand Over/Under Total Goals betting and gives you a few practical tips to improve your chances.
Would you like this translated into a more casual tone or kept formal for publishing?
Utilisateur(s) parcourant ce forum : Bing [Bot] et 1 invité
