 Forum de l'association French-Drift-Community • Consulter le sujet - U4GM - 7 Facts About Soft Caps for Elden Ring Runes You Shou
Message par Ruckusflare » 11 Juin 2025, 10:07
Understanding how soft caps work in Elden Ring can drastically improve how you spend your runes and allocate attributes. These thresholds determine the point at which leveling up a stat becomes less effective, impacting everything from damage output to FP and stamina. If you're investing time grinding or even looking into Elden Ring Items for sale, knowing these soft caps helps you plan smarter and avoid waste.
Here are seven important facts every Tarnished should know:
1. Soft Caps Vary by Stat
Unlike previous FromSoftware games, Elden Ring sets different soft caps for each attribute. For example, Vigor hits diminishing returns after 40, while Strength and Dexterity start to plateau around 18, 55, and then again at 80 depending on your weapon scaling. This means planning your build with these breakpoints in mind is crucial.
2. You Can Still Level Past Soft Caps
Hitting a soft cap doesn’t mean you should stop leveling that stat entirely—it just becomes less efficient. For example, increasing Intelligence past 80 still gives some bonus to magic power, but it’s marginal compared to the gains up to that point. If you’re investing heavily or browsing elden ring runes for sale, make sure you’re not overcommitting without reason.
3. Three-Tier Soft Cap System
Most stats follow a three-tier soft cap system. Take Dexterity as an example:
First cap at 18: noticeable early returns
Second cap around 55: optimal balance point
Final cap at 80: minimal gains afterward
Knowing these layers helps you decide whether to specialize or stay flexible with hybrid builds.
4. Weapon Scaling Plays a Role
Some weapons have scaling that synergizes better with high stats even beyond the soft caps. This is especially relevant for quality builds, where both Strength and Dexterity contribute to damage. So even if you're using Elden Ring Items for sale to fast-track your equipment, you still need the right stats to get the most out of them.
5. Mind and Endurance Have Hidden Soft Caps
Mind affects FP, and its first cap is at 20, with additional thresholds around 50 and 60. Endurance, which controls stamina and equip load, has caps that influence both separately. Stamina gains halt at 50, but equip load continues to rise. This distinction matters, especially for tankier builds or spellcasters using heavy armor.
6. Hybrid Builds Benefit from Strategic Allocation
Players running hybrids like Spellsword or Battlemage need to balance stats carefully to avoid wasting runes. Rather than pushing one stat to its cap, it’s often better to spread out and get solid gains across several attributes. If you’re optimizing after grabbing elden ring runes for sale, a balanced approach can stretch their value much further.
7. Respecting Soft Caps Helps When Respeccing
Using a Larval Tear to respec is a great chance to reset your attribute points. If you’ve been experimenting or following multiple builds, it’s easy to accidentally overshoot soft caps. Reviewing your current plan and redistributing accordingly ensures you get the most bang for your buck—or your time, especially if you’ve been grinding hard or shopping at U4GM for a boost.
Soft caps are essential for effective leveling in Elden Ring. They help define build paths, inform decisions on attribute investment, and ensure your rune usage is efficient. Whether you’re farming manually or considering external help like U4GM, understanding how these thresholds work will always give you an edge in the Lands Between.
Ruckusflare
Message(s) : 6
