 Forum de l'association French-Drift-Community • Consulter le sujet - Craft AION 2 Superior Manastones Smarter With U4GM Guide
Message par 1fuhd » 10 Oct 2026, 07:50
Getting stronger in AION 2 is not just about finding better equipment. The bonus stats engraved on your weapons and armor can make a noticeable difference in combat, especially when preparing for difficult bosses or PvP encounters. Superior Manastones give you more opportunities to fine-tune your build, but their randomized results mean you should plan before spending valuable materials. If you are still upgrading your setup, browse Aion 2 Items to explore equipment and progression resources.
What Are Superior Manastones?
Superior Manastones are used to add bonus attributes to compatible weapons and armor through the engraving system. Depending on the result, these bonuses can improve damage, accuracy, survivability, or other aspects of your character.
Possible attributes include:
• Offensive stats: Attack, Critical Hit, and specialized damage bonuses.
• Accuracy: Helps improve offensive consistency against enemies.
• Defensive stats: Defense and HP for better survivability.
• Advanced damage bonuses: Damage Boost, Weapon Damage Boost, Critical Damage Boost, Front Attack Damage Boost, and Back Attack Damage Boost.
Superior Manastones can produce different stat qualities, including Rare, Epic, and Unique results. However, using a Superior stone does not guarantee a top-tier bonus.
One important detail: accessories use Soulstones rather than ordinary Manastones. Check your equipment type before investing in crafting materials or deciding to buy Aion 2 Items.
How to Get Superior Manastones
1. Craft Them Through Alchemy
Alchemy is a repeatable way to obtain Superior Manastones. One listed recipe requires:
• 30 Intermediate Manastones
• 10 Spiritstone Powder
• 2 Exceptional Ink
Recipe requirements may vary by version or ingredient type, so check the crafting interface before gathering materials.
2. Craft Lower-Tier Manastones
Do not overlook Lesser and Intermediate Manastones. They remain useful because lower-tier materials can feed into the crafting process, and an Intermediate Manastone recipe may produce a Superior Manastone through a great-success result.
3. Claim Progression Rewards
Bound Superior Manastones may also be available through achievements, battle-pass rewards, and Growth Manastone Chests. Check these sources before spending Kina on additional materials.
If you need to prepare several equipment pieces at once, comparing cheap Aion 2 Items can help you review potential options for your progression needs.
How to Engrave Superior Manastones
Follow these steps to add bonus stats to your equipment:
1. Open the Enhancement interface.
2. Select the Manastone section.
3. Choose compatible equipment with available engraving slots.
4. Register your Manastones and review the displayed probabilities.
5. Pay the required Kina fee and confirm the engraving.
6. Check the resulting attributes before deciding whether to reroll.
Engraving outcomes are randomized, so do not expect every attempt to produce your preferred stat. Current guides also describe rerolling selected slots, allowing you to replace unwanted attributes while preserving useful bonuses. Always review your selection before confirming.
Which Stats Are Best?
The right Manastone depends on your class, equipment, and combat style.
• Damage-focused builds: Prioritize Attack and suitable damage bonuses.
• Critical builds: Look for Critical Hit and Critical Damage Boost when they support your setup.
• Positional attackers: Front Attack Damage Boost or Back Attack Damage Boost may be valuable if you consistently meet their conditions.
• Struggling with survival: Consider HP or Defense instead of chasing offensive stats alone.
A rare attribute is not automatically the best choice. A practical bonus that improves your actual performance can be more valuable than an impressive roll that rarely benefits your playstyle.
Tips for Saving Materials
• Use lower-tier stones on temporary gear.
• Save Superior Manastones for equipment you expect to keep.
• Keep enough Kina available for repeated engraving attempts.
• Stop rerolling when your current bonuses already work well.
• Check whether reaching 100% Soul Binding unlocks an additional Manastone slot on eligible equipment.
Superior Manastones offer a useful way to turn decent equipment into a build that better suits your needs. Craft them through Alchemy, collect free progression rewards, and prioritize stats that improve your performance rather than chasing perfect rolls on every item.
A little patience can save a lot of materials over time. If you are preparing for your next equipment upgrade, check the available Aion 2 Items for sale and focus on the resources that will make the biggest difference to your character.
1fuhd
Message(s) : 4
Utilisateur(s) parcourant ce forum : Majestic-12 [Bot] et 13 invité(s)
