 Forum de l'association French-Drift-Community • Consulter le sujet - Playing Genshin Impact China Server Overseas
Message par yezi8899 » 25 Août 2026, 03:26
If you play Genshin Impact on the China server from overseas, high ping, connection drops, delayed actions, and unstable gameplay can quickly become frustrating. Even with fast local broadband, the connection to mainland China may still feel slow because of long-distance routing, network congestion, and packet loss.
Why Is Genshin Impact So Laggy Overseas?
The biggest issue is usually not your computer or phone, but the network route between your location and the China game server. Data has to travel across international networks before reaching the server, and busy routes can introduce additional latency and instability.
Typical problems include delayed character movements, slow teleportation, skill-response delays, lag spikes during combat, and unstable co-op sessions. These issues can become especially noticeable during peak hours.
Before changing anything, it is worth checking whether other devices or background applications are consuming bandwidth. Using a wired connection or a more stable Wi-Fi network can also help.
How to Improve Genshin Impact China Server Ping
For players who have already optimized their local network but still experience high latency, a gaming accelerator can be another option. The goal is to use a more optimized route between your overseas location and the Chinese server rather than relying entirely on congested public routes.
SpeedX Stable China VPN is one option worth considering for overseas players who regularly access China-based games and services. Its focus on optimized China routes can help improve connection stability and reduce unnecessary routing, although actual results will vary depending on your country, ISP, distance from China, and current network conditions.
For the best results, choose a node that is appropriate for your location and test it during the hours when you normally play. SpeedX 海外访问中国加速器 can be particularly useful for players who want a simple way to optimize their connection without constantly adjusting network settings.
A Better Overseas Genshin Impact Experience
There is no way to completely eliminate the latency caused by physical distance, but a better network route can make a noticeable difference. If you are playing the Genshin Impact China server from overseas and experiencing persistent lag, start by checking your local network, then consider a dedicated acceleration solution such as SpeedX.
With a more stable connection, everyday exploration, domain challenges, combat, and co-op sessions can feel considerably smoother—even when you are thousands of kilometers away from the China server.
yezi8899
Message(s) : 2
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 13 invité(s)
